Reload this Page >
CARF REBEL 2m
CARF REBEL 2m
Old 03-07-2020, 08:35 PM
  #51
bodywerks
bodywerks's Avatar
Nice! So just over 1:1 thrust at take-off. Just how I like it!
Old 03-08-2020, 09:12 AM
  #52
skymaster68
That Scheme is SuperCool!! I might steal it from you when I order my Pro!! 😁
QUOTE=bodywerks;12585757]Those of you with Carf version 2M Rebel, can you weigh yours for me? Empty weight, full UAT. it might help me decide on a turbine for mine before I actually have it in my hand and assembled. I just placed a custom scheme order for the Classic through Ray. This scheme:
[/QUOTE]
Old 03-08-2020, 09:17 AM
  #53
skymaster68
it has a 160 turbine migh that be the difference, and also who knows what size UAT and equipment it has... 🤷🏻‍♂️
i can weight mine with a 120 and a 100cc Uat from Fct next week in case if you still need the info, I dont run any pwr box or so, just 12ch rx, wireless switch and a cortex pro, 2 2600 jeti lion Batt and a 2100 mah liffe...
Originally Posted by bodywerks
Thank yThat's 4 pounds heavier than Carf lists it. They claim 20-22lbs dry.
Old 03-08-2020, 06:53 PM
  #54
bodywerks
bodywerks's Avatar
With Swiwin, the difference between the 120/140 and the 160/170 is only a half-pound. I'm KISS, also. Just Spektrum powersafe rx, no switch, no gyro, and three batteries total.
Old 03-24-2020, 08:30 PM
  #55
bodywerks
bodywerks's Avatar
Originally Posted by dmac
Mine is 22#-6oz. with full uat. Weighed on Xicoy balancer.
My buddy just finished a Carf version with a tuned down K-160. 24lbs on the nose, uat full. IMO, this is pretty light!
On a side note, his jet has quite the whistle in flight. does anyone else get the whistle?
Old 03-24-2020, 09:25 PM
  #56
causeitflies
causeitflies's Avatar
Is it an airframe whistle or an engine whistle? If it's an engine whistle (usually heard at higher throttle) it may be too far from the pipe.
Old 03-25-2020, 01:30 AM
  #57
bodywerks
bodywerks's Avatar
Funny you should say that, because on his first flights he had the end of the turbine exhaust 1.25" forward of the opening of the BELL of the tailpipe instead of the from where the actual tailpipe started. We were sure that was it. But the next day he moved the turbine back some 2 inches to be only about 3/4-1" from the start of the tailpipe, and the whistle was exactly the same in flight.
I'm pretty sure it is either an airframe whistle, or the servo arms he is using. They are Futaba, I believe, and the rudder one might be at just the right angle to cause a whistle with air passing through it:
https://www.google.com/imgres?imgurl...MygsegUIARCyAg
Ruizmilton (04-28-2020)
Old 03-25-2020, 03:31 AM
  #58
skymaster68
mine also whistles 🤪
Old 03-25-2020, 06:20 AM
  #59
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Mine has an airframe whistle as well. It is common.
Old 03-25-2020, 08:28 AM
  #60
causeitflies
Well there you go. Some planes are whistlers and some are howlers
bodywerks (03-25-2020)
Old 03-25-2020, 10:33 AM
  #61
Dave Wilshere
I think there is a delivery of these just into the US, sounds like perfect timing to get one built if there is some down time!
The following 2 users liked this post by Dave Wilshere:
bodywerks (03-25-2020), DenisFerrari (12-18-2021)
Old 03-25-2020, 03:49 PM
  #62
skymaster68
I sold my Classic Rebel today, it was a awesome fun plane to fly...
Now I’m going PRO!! 💪🏻💪🏻💪🏻💪🏻
Old 03-25-2020, 10:22 PM
  #63
bodywerks
bodywerks's Avatar
I added a Pro to my order as well, in the same custom MAX scheme that I posted earlier! Mine will be markedly over-powered, just like my rebel HOT is(16lb full take-off weight with an 85N turbine). Turbine will be somewhere in the 240-250N range
Old 03-26-2020, 03:44 AM
  #64
skymaster68
240-250 !!! thats way to much and don’t need it.... the Max’s arriving here will all be 210’s
I saw it at at JP and it had a 260 but never when abobe 75% of power, (my friend did the flights there) as you know this are super light... KT I heard is having a 220 very soon and for my Pro it would be just 180, I’ve flown a Pirotti on a P180 and was superb..
I’ll go with the new K180G4 that uses the same case of their k160G2 so it’s gonna be light...
Old 03-26-2020, 08:07 PM
  #65
bodywerks
bodywerks's Avatar
My Rebel HOT with an 85, I don't find to be over-powered at all for my flying style, even at a 1.2:1 thrust to weight ratio at take-off. I also know how to use my left stick and do so, all the time.
The smallest turbine I would go with would be a 210, but I honestly know I will likely be disappointed in thrust performance, unless I can get TO weight to 40lbs - which, with smoke, I don't see happening. If the 240-250 that I am looking at ends up only being a pound or so heavier than the 210 while offering 10lbs more thrust, it's a no-brainer for me. I personally love the idea of not over-working a turbine. They stay happier for longer that way.
My Rebel classic is getting a 170 It's in my 2.2M predator right now and I find the power to be only 'satisfactory'...
I should also add that where I fly has a density altitude almost always above 5,000 feet, and nearing 10,000 feet in the summer, which may be factoring in on my personal taste as far as power goes.
Old 04-05-2020, 12:14 PM
  #66
A7Bldr
My Feedback: (40)
Would it be possible for someone to snap a pic of the exhaust opening at the rear of the fuselage with a ruler showing the width?
I was wondering about EDFpossibillities.
Thanks, Jim
Old 04-05-2020, 12:41 PM
  #67
Dave Wilshere
Would have thought the tiny inlets were more the issue.
Old 04-05-2020, 01:12 PM
  #68
A7Bldr
My Feedback: (40)
I haven't been able to see one in person so maybe it is the issue, but perhaps there are ways to creatively add inlet air.
Schubeler likes to add NACA ducts, etc.
Usually the exit size is too small, so that's what I'd like to see 1st.
Old 04-06-2020, 10:43 AM
  #69
Desertlakesflying
My Feedback: (28)
This is the largest thrust tube you would get in there. Mine is about 22lbs without fuel.
N4S (07-05-2022)
Old 04-06-2020, 11:04 AM
  #70
A7Bldr
My Feedback: (40)
Thanks for the photo; it looks promising.
Jim
Old 04-06-2020, 12:25 PM
  #71
Dave Wilshere
On the CARF Hawk I did with a DS-98 I shaped the outlet to get it as big as possible, it was slightly off round. You have a lot to play with there on outlet. It’s still how are you going to feed the fan!
Old 04-06-2020, 05:51 PM
  #72
A7Bldr
My Feedback: (40)
Dave, I'd consider opening up one or 2 of the black squares on the fuse side ahead of the inlets (the black trim scheme) and also look at adding a NACA duct on the bottom.
I'd run a bell-mouth and no intake ducting (or perhaps very short ones from each side).
I don't know how much intake area there already is, so I don't know how much extra area is needed; (do you have one to measure?)
These are just some
ideas and may not be feasible.
I have the CARF Viperjet and marvel at the lightness and strength. Gotta be an EDF option on this one, somehow....
Jim
Old 04-06-2020, 08:39 PM
  #73
Desertlakesflying
My Feedback: (28)
I almost threw mine through the ceiling it was so lite when I first took it out of the box expecting it to weigh as much as the T-One did.
Old 04-07-2020, 01:37 PM
  #74
bodywerks
bodywerks's Avatar
Did you just get one? You didn't have it at Coachella. Mine should be here mid May. They are impressively light.
Old 04-07-2020, 03:16 PM
  #75
Desertlakesflying
My Feedback: (28)
Ordered it right before Tucson. Had it done and ready to go to Tucson when I figured Tucson would be cancelled and headed home.
Been loving it. Sold the T-7 on the way there.
bodywerks (04-07-2020)
