Magnum vs O.S.
Magnum vs O.S.
I am about to start construction on a BTE Venture 60 (think Sig Four Star 60) and I initially intended to install a two stroke OS .65 AX. I noticed on the Tower Hobbies site that Magnum engines are about half the cost of comparable OS engines, and that for the price of a O.S. 65 AX I could nearly buy a Magnum XL 70 four stroke and an XL 91 four stroke is only $30 more!
Does anyone have any experience with Magnum engines? I assume they aren't as good quality as OS but if they are reliable enough for easy sport flying I may just buy the Magnum four stroke.
Would you rather have an OS two stroke or a Magnum four stroke?
I understand that an OS or Saito four stroke would be ideal, but I am simply not going to spend $350+ on an engine just because it sounds better than a $180 two stroke OS. The only way I'm going four stroke is if it is around the same price as the OS two stroke.
Magnum engines have been discussed a great deal. The general opinion seems to be that they can be good engines, but Magnum's quality control is not as good as OS or Saito. That is, your chance of getting a bad Magnum is greater than your chance of getting a bad OS or Saito. I happened to buy a Magnum that was a dog - it had an air leak that I was never able to track down. But there are many people who are perfectly happy with their Magnums. Search on Magnum on this forum for more information. I don't remember it all too well.
I would get a two stroke Magnum, mostly because there is less chance for fit problems and air leaks. KISS keep it simple s___. I generally like two strokes best because of the simplicity. Magnum/ASP have been improving lately, so a new one may not be as much of a gamble as it once was.
If you buy Magnum buy new with a warranty. My first Magnum four stroke was a 52 and it had leaky valves and a tooth broken off the cam gear, after sending it back twice they replaced it with a new engine and that one runs good. Not as refined as an OS or Saito but serviceable. Have you thought about a good used engine? brucercengines.com has loads of proven used engines in stock
I like my Magnum 4 strokes. My .91 is over 10 years old and has always ran great, My .52 only has a little time on it but no problems. I would say they are only about 90% as powerful as the same OS. Someone opened up the OS and Magnum side by side. Things like the valves were smaller on the Magnum. If you dont care about having the most powerful engine it is just fine. My 91 was in a CG Ultimate until the elevator pushrod broke and has spent the rest in a Pica Jungmeister. The .52 is in a VK Dr1.
Thanks for the advice guys! I will look at brucercengines.com and see what they have. I am not above getting a used engine as long as it comes from a reputable source. I have been following eBay closely too.
I have got dozens of OS motors used, and for the most part have been happy. Most were under $20. I don't think I even bought one new. I prefer the other Chinese brands new, as they have been better as they learn how to make them. OS stuff went through a learning curve too, but it was a loong time ago.
Jaybird
The good thing on Magnums is that tinkering with them everytime you are at the field makes you become an engine expert in the eyes of the unexperienced or electric fliers. It doesn't matter if you get them running or not.
NY
Dan you, HIT THE NAIL ON THE HEAD!!!! I always try and steer new pilots away from used engines and too OS engines. I figure if they learn to fly first, They can learn to "fiddle" with engines later. I couldn't have said it better, and I would consider any engine on the bay as "Not working" no matter what the add says. If you get one that works, Consider yourself one of the lucky ones. Thanks Kevin
My experience with Magnum has been good, but I've never experienced a single problem with a new O.S. Ready to go right out of the box. Two tanks on the ground slightly rich then they're ready to fly.
I also got another engine almost for free from someone who claimed he had tried everything. It was grossly out of tune on the low speed needle, and had a very cold plug in it. It had also survived a deadstick crash on a hard surface. Nothing is wrong with the engine. 8^)
Brucercengines is a good bet because he tests every used engine. Regarding Evolution engines the one 46 glow that I have is a good runner. And regarding OS although they are generally good my 52 Surpass doesnt run right. And I have tried everything even replacing the carb and will next try a new cam. The rest of my OS engines run good.
