Vortex F3A build thread
Old 05-28-2020, 10:31 AM
  #201
AndersonR
AndersonR's Avatar
Hi Alex i have other question
On folderVortex_Drawings_BF \ Vortex_Drawings_BF \ 1_LASER CUTTING FILES \ 1_Hard Plywood 1.5mm
This folder 1_Hard Plywood 1.5mm for balsa 1.5mm he will connect with fuselagem 3mm why this folder is front part Vortex will work plug connect 1.5m to 3mm?
Old 05-28-2020, 10:48 AM
  #202
Alex Voicu
[QUOTE=AndersonR;12607801]Hi Alex i have other question
[QUOTE]
Sorry, i'm not sure i understand the question. As specified in the name of the sheet and folder, these parts are made of 1.5mm plywood, not balsa. The 3mm balsa sidewalls will cover the fuselage from firewall to tail, so that includes the 1.5mm plywood parts in your pictures.
Old 05-31-2020, 09:17 PM
  #203
torti72
I have a somewhat crazy idea ...
Can someone tell me the approximate weight of one wing half?
Then I can estimate whether my project is feasible.
Thank you!
Old 06-01-2020, 12:43 AM
  #204
Alex Voicu
Thank you!
Hi,
My wing panels are 265g each, without servo, linkage or covering. Weight with covering should be around 320g.
Old 06-01-2020, 12:53 AM
  #205
torti72
Thanks Alex! That sounds good. My wing will be a total of 50g heavier ... so doable.
Old 06-18-2020, 11:20 PM
  #206
robin24
Hello!
Since it is a wetter summer in our country, l find an our every day and polish Alexs Vortex kit a bit.
Its amazing how nice things go together. At the moment l have made both directions, fixed and movable.
I wonder what kind of hinges Alex recommends for height, direction and ailerons?
Congratulations again to Alex for the outstanding work he shared with us.
Unfortunately, l cant take pictures...
BR Robi
Old 06-19-2020, 12:39 AM
  #207
Alex Voicu
Hi Robi,
I'm glad everything goes well with the assembly, please keep us updated.
I bought a few bags of Radiosouth CA hinges some years ago and used them for all my models:
https://radiosouthrc.com/radio-south...ts/pro-hinges/
I have the 1/4 scale version (yellow bag cover). These are probably the strongest CA hinges that you can find, but i think other CA hinges may work as well.
Old 06-19-2020, 12:51 AM
  #208
robin24
Alex, thanks, maybe the possibly the size or dimensions of the tile...?
BR Robi
Old 06-19-2020, 07:38 AM
  #209
Alex Voicu
Sorry, the hinges are back home and i can't measure them. I think they are approx. 25x20mm.
Old 07-07-2020, 07:25 AM
  #210
lofl
lofl's Avatar
Any further flight videos Alex?
Old 07-08-2020, 02:25 AM
  #211
Alex Voicu
Sorry, i don't have anything new.
Old 07-10-2020, 11:28 PM
  #212
Tolvai
Alex, good afternoon! I wanted to ask, tell me, please, what is the length of the fuselage? I wanted to know the exact size in millimeters.
Old 07-11-2020, 09:59 AM
  #213
Alex Voicu
Hi Tolvai, the total length of the fuselage is 1996mm with a 71mm long spinner.
Old 07-11-2020, 10:27 AM
  #214
Tolvai
Алекс, большое спасибо за ответ. Я хочу объяснить, почему я узнал размер. У меня есть пилотажная модель apollo-120. Есть настройка на 8с. Мне очень понравился ваш проект. И я хочу уменьшить ваш самолет на 10%. Это будет около 1750-1800 мм в размере. Я надеюсь, что я не расстроил вас своим решением. Но 2 метра это дорого и мне очень сложно транспортировать. И здесь у меня есть все настройки.
Old 07-11-2020, 10:29 AM
  #215
Tolvai
Спасибо!
Old 07-12-2020, 07:27 AM
  #216
Tolvai
Алекс, спасибо за информацию. Могу ли я узнать, какой размер в миллиметрах у меня есть крылья?
Old 07-13-2020, 09:16 AM
  #217
Tolvai
Спасибо!
Old 07-18-2020, 02:55 AM
  #218
Tolvai
И еще один вопрос. Включен ли материал обшивки самолета в представленные файлы лазерной резки? Верно?
Old 07-18-2020, 02:57 AM
  #219
Tolvai
And one more question. Is the aircraft skin material included in the submitted laser cut files? Right?
Old 07-18-2020, 03:51 AM
  #220
Alex Voicu
Only the 3mm fuselage flat sides are included in the laser files.
I don't think it's possible to flatten the double curvature surfaces with enough accuracy, at least not with Solidworks. Different balsa grains have different properties, and also the balsa sheets have different properties in the direction of the fibers and perpendicular to it, which makes things a lot more complicated for computer simulations.
The following 3 users liked this post by Alex Voicu:
flyintexan (07-21-2020), robin24 (07-18-2020), Tolvai (07-20-2020)
Old 08-30-2020, 10:32 PM
  #221
Sasha doctor
Dear Alex, have you ever flown your Vortex P21? Are there any flight features?
Old 08-31-2020, 12:29 AM
  #222
Alex Voicu
Hi Sasha,
I didn't make any progress with my Vortex, the corona situation makes it difficult to ship my planes and tools here in Sweden. Krille made a set of composite parts for me and i will continue when it will be possible.
Krille is flying the Nordic schedule with his Vortex and he seems to be very happy with it. He reported that it flies especially well in high winds, something that was noted by all other pilots watching his flights.
wattsup (08-31-2020)
Old 09-09-2020, 08:54 AM
  #223
Alex Voicu
I received some pictures from Andrey, a very talented and experienced builder from Russia working on a Vortex model. He has an interesting build thread on the russian forums and i actually learned a few tricks from him: http://forum.rcdesign.ru/f128/thread556829.html
He made his own composite parts and he is willing to make cowls and canopies for other builders. If you want to contact him, just send me a PM and i'll give you his email address.
The following 2 users liked this post by Alex Voicu:
Andrey15 (09-16-2020), Tolvai (01-30-2022)
Old 09-09-2020, 08:58 AM
  #224
Juanemartinboix
Superfinish!!!
Old 09-21-2020, 11:09 AM
  #225
GorillaToast
Alex, I just want to say that this build thread is very informative. Thanks so much for posting it.
One quick question... in the first page, you have pictures of the fuselage construction and it looks like you are holding the bottom pieces down to a melamine topped building board with straight pins. Is that correct? I can't even begin to get a T-pin to go into melamine.
