Vortex F3A build thread
Old 07-31-2023, 10:15 AM
  #301
frequent flyer
frequent flyer's Avatar
Default Version 3 kits
duplicate post deleted
Old 09-16-2023, 11:10 PM
  #302
stalk
Sorry
Old 09-25-2023, 10:13 PM
  #303
amahillo
Default Composite fuselage
After several months working on a composite fuselage for Vortex we have seen the first fuselages come out of the molds
One for been used as electric and the other one for been used with Gas-glow engines . Pictures soon
Old 09-27-2023, 02:01 AM
  #304
amahillo
The following 2 users liked this post by amahillo:
Ricardo M. (09-27-2023), robin24 (11-16-2023)
Old 09-27-2023, 06:17 AM
  #305
Juanemartinboix
Nice, can you describe the layup, construction?
Old 09-28-2023, 02:33 AM
  #306
amahillo
Thanks for your interest! The layup’s quite simple: glass / Herex / glass, 50gr/sqm inner and depends on the version 50 or 100gr/sqm outer side. Then 200gr/sqm carbon in the front area outer side with some reinforcements here and there for the undercarriage and engine/motor area. Cabin and under belly glass 50 + 100gr/sqm.
Cheers,
robin24 (11-16-2023), wattsup (09-28-2023)
Old 09-28-2023, 09:36 AM
  #307
Juanemartinboix
Talking
Cheers,
Thanks for the photos. Now go for the wings
Old 12-05-2023, 01:25 AM
  #308
christian_oele
Could you please tell me, if there is a glow version of the balsa/wood Vortex version ?
If yes, how is the engine mounted ?
KR, Christian
Old 12-05-2023, 07:50 AM
  #309
frequent flyer
KR, Christian
Yes , Alex and I made a glow version.you can email me for more infomation on the ys kit.
Old 12-06-2023, 12:16 AM
  #310
christian_oele
Has anyone else done a glow conversion ?
I am looking for plans, not for a kit (frequent_flyer (Don) offers kits only).
Thanks and KR, Christian
Old 04-08-2024, 12:40 AM
  #311
Rainer F
Hello everyone,
I'm Rainer from Germany and at the end of February I started to mill Alex's beautiful Vortex.
So far I have milled all the plywood and the 3mm balsa. The hull is built up so far that I can start with the 2mm balsa planking, I'm just waiting for another delivery of balsa to make the cable duct from 0.8mm balsa and glue it in. I will post a picture this afternoon.
But I have a question about the undercarriage. On the pictures it looks like a Falcon undercarriage, but what height is needed if you want to run a 22" propeller?
CLG001 with 200 mm height (upper surface to Center of Wheel Axle)
CLG002 with 216 mm height (upper surface to Center of Wheel Axle)
CLG004 with 234mm height (upper surface to Center of Wheel Axle)
I hope the holes in the landing gear mount correspond to the pre-drilled Falcon landing gear legs.
Thanks Rainer
Old 04-08-2024, 05:14 AM
  #312
underdw
underdw's Avatar
Mine is the composite version. I measured about 213mm from axle to upper surface. This provides plenty of ground clearance for 23" props. Your mount may be different though.
Dan
Originally Posted by Rainer F
Hello everyone,
Thanks Rainer
Rainer F (04-08-2024)
Old 04-08-2024, 06:35 AM
  #313
Rainer F
Hello Dan,
thanks for the info. I'll wait and see if someone else writes something about it. But 213 mm seems to fit very well. I will measure that.
I don't think I can add any pictures yet as this is only my second post.
Thanks Rainer
Old 04-08-2024, 07:00 AM
  #314
Rainer F
http://www.rc-network.de/threads/vor...#post-12746703
There are pictures of the construction of the vortex
