Reload this Page >
CARF Joker build thread
Old 05-03-2018, 12:20 PM
  #176
Bob_B
Bob_B's Avatar
That looks like an EDF version of the Inspiration which CARF made for Graupner!
Where did you find that image? website address please.
Old 05-03-2018, 12:25 PM
  #177
Midas D.
Old 05-03-2018, 12:26 PM
  #178
opjose
opjose's Avatar
Originally Posted by Midas D.
Is there any one able to show some picture of how and where of the battery instal?
@ Dave, is there an other then the Stock Carf (lighter) pipe out there?
Started giving the woodwork on the inside some sealing/coating.
K85 is on it's way, i go for the "Light weight" version is suppose ....
Cheers,
Ed
Here is how I did mine
Old 05-03-2018, 12:27 PM
  #179
Midas D.
http://www.rcuniverse.com/forum/rc-j...ead-flown.html
But i guess you got to be quick cause i think this thread will disappear in to thin air rapidly .....
Old 05-03-2018, 12:29 PM
  #180
Midas D.
Thanks opjose, appreciated
Old 05-03-2018, 12:31 PM
  #181
Midas D.
Old 05-03-2018, 12:56 PM
  #182
opjose
opjose's Avatar
PLEASE bench test your K-85G first, particularly if you are going to use Diesel.
Old 05-03-2018, 01:04 PM
  #183
skymaster68
any particular Reason Of doing that? I’m running 4 KT Turbines On diésel including an 85 and have never bench test Them before mayden them....
Old 05-03-2018, 01:32 PM
  #184
opjose
opjose's Avatar
My K-85G had numerous issues out of the box.
The starter motor was bad and not spinning the turbine up to full RPMs, which caused a beautiful hot start that melted the pipe before I could even see it since the back of the engine is not visible in the Joker.
On the Kingtech forums almost everyone suggests modifications to parameters on the ECU to get good diesel starts.
Had I bench tested it first, I would have it dialed in before the first start in the plane.
Old 05-03-2018, 09:11 PM
  #185
Midas D.
Thumbs up K85
Will do, thanks for the heads up!!
Just out off curiosity, does it run and start smooth now after you reset the parameters?
Cheers,
Ed
Old 05-03-2018, 09:19 PM
  #186
Dave Wilshere
Ed, sorry been busy trying to get various projects done in time for collection/ weekend. Maybe the stock CARF pipe is a thinner grade, as I typed before something in my mind said it was not so heavy on the Joker, though I’m still surprised there is not a greater difference. Some of those pictures are of my friends P-60 powered Inspiration (still flying) You can’t have ducting and such a low price/weight
Old 05-03-2018, 09:38 PM
  #187
Midas D.
Cheers Dave,
I hear yah
Would it not be possible for Carf to start building the ducting again and add. on the option/spare parts list?
So one can decide for them selves to add. or not to add. and spend the money
Cheers,
Ed
Old 05-03-2018, 11:41 PM
  #188
Dave Wilshere
No, turbine position and wood work is all new, would need saddle tanks and completely new ducts would need moulding, it's not what this aeroplane is all about, it was kept super low cost for a reason and speed/energy managed for pilots coming from the Xcalibur. Otherwise buy an UF.
Old 05-04-2018, 12:25 AM
  #189
TUMBLER
My Feedback: (13)
So what kind of speed can you expect with an 85?
Old 05-04-2018, 11:04 PM
  #190
Dave Wilshere
Why is speed the number that’s important? Most people are really poor at judging speed, so it’s just a number. What vertical will it have and will it pull big loops is much more relevant. Will it have enough power to fly a nice schedule with an 85? Yes, presuming you are not based somewhere really high, it will have great performance.
Old 05-07-2018, 03:17 AM
  #191
Midas D.
All the bit's and pieces are slowly entering the "man Cave"
Did the plumbing yesterday on the tank and UAT.
Who off you guy's is also going or using all the stock supplied stuff?
I never used the stock stuff, and alway's used after market parts, but on this one i want to keep it all as it came out of the box.
Any suggestions on this??
The hopper supplied by Carf, someone out there using it? And does it work fine or is it an absolute no go?
Cheers,
Ed
Old 05-07-2018, 03:47 AM
  #192
dccatl
Cheers,
Ed
I used a BVM UAT in place of the stock hopper. For everything else I used the stock components.
Old 05-07-2018, 06:57 AM
  #193
Dave Wilshere
Hopper works perfectly if you can be bothered to assemble it. In the case of the Joker you can use everything supplied
D
Old 05-08-2018, 06:42 AM
  #194
Midas D.
Well all the goodie's are in the Cave, so lets step on it!!
About the "Buy a Flash" statement.....
Arrrgggg, this is an understatement in my Opinion, Quote... Small Sport jets are trendy...!
Took this directly off Carfs website.
And looking at it and mentioned several times before, Yes they are!!!
If you see the most amount of turbine's sold at this time are the smaller ones, simply because smaller jets are in all perspective much easier and a Hell of lot cheaper to operate the the bigger brothers.
Saying this the statement "Buy a Flash" should have been, Carf scratch your head and put a mini Flash on the market!!
Instead off blowing the dust off some old moulds.......
That would be a blast .....
Never the less, looking forward to the build and flying the Joker. Easy peasy jet, can't wait
Just my 2 cent's
Old 05-08-2018, 07:45 AM
  #195
LA jetguy
LA jetguy's Avatar
I would buy an "Ultra Flash" before CARF discontinues it like the Spark. I'm sure the replacement for the Ultra Flash will be very similar to the Joker and on the "simple", "thinner" all installed (Retracts and servos) version... I don't think I will be able to put a 200 size engine in the UF 'replacement' and get to 300++ mph...
Buy an Ultra Flash and store it...
David
Old 05-08-2018, 08:21 PM
  #196
LA jetguy
LA jetguy's Avatar
Maxed out the SB-IAS sensor at 235 mph... getting the other model with 1200KPH limit.
Old 05-08-2018, 08:37 PM
  #197
DrV
DrV's Avatar
That was a very nice flight LA Jetguy. Thanks for letting me fly it as well. It's a beast with that K-120. Congrats!
Old 05-08-2018, 08:56 PM
  #198
DepecheMode101
I was there today and I am sure the flight before this one was much faster.... This is a quick jet I wish I could $$$ one!!!
Old 05-09-2018, 11:57 AM
  #199
Midas D.
Did the bench test today, absolutely painless
No flames or wet/hot start behavior what so ever.
Time to put it in it's new home
Old 05-09-2018, 07:50 PM
  #200
TUMBLER
My Feedback: (13)
To each his own I guess. I don’t really care about vertical and loops. Don’t think I have ever had a jet that didn’t have good vertical or had trouble looping. Speed and precision are more important to me. I have a JTM XXX roughly the same size as the Joker radared at 180 and I know I want the Joker to be at least as fast. I have had an UF which is much faster and don’t need that kind of speed out of the Joker, but I know 150 will be boring for me.
So if I have to put a 100 in it to get the performance I want then I will, but if I don’t have to, id rather use a lighter 85. Why are there no videos of one flying with an 85. I just bought a Joker and Ray Labonte is trying to track down a video.
