Reload this Page >
CARF Joker build thread
Old 01-15-2018, 03:17 AM
  #126
JP-1
The one in green looks good.
A.P.
Old 01-17-2018, 07:56 AM
  #127
hk3957w
hk3957w's Avatar
good day, some weeks ago I bought the joker, its gonna be my first jet I live in bogota at 2600 mts over sea level and want to fly in my grass field. what turbine engine I must buy? what is your recommendation? i am thinking on jet cat 100 rx or king tech 120. considering the grass field and the altitude I thing best option is 120 but I’m not sure.
thanks javier
Old 01-17-2018, 08:57 AM
  #128
Dave Wilshere
Javier
The model flies with a 60N turbine, 80N is good performance and P-100Rx is perfect for your use.
Dave
Old 01-18-2018, 06:29 AM
  #129
essyou35
So are the jokers tough like the flash/lightning? Can they handle being over powered?
Old 01-18-2018, 08:22 AM
  #130
Dave Wilshere
No. 100N maximum. It's made lighter, its not the usual CARF tank.
Old 01-18-2018, 07:17 PM
  #131
hk3957w
hk3957w's Avatar
thanks dave for your advice. but with 100N its enough to beat the grass and the lost of power because the altitude? how many kgs I will lose with this altitude? i thing 92% will be the total achieve power or maybe less at this altitude. thats mean if I have 100N I will lose close to 1 kg of power and will be close to the aircraft weight thats my concern.
I just have one shot to get the right engine.
thanks again dave, gentlemen,s
Old 01-18-2018, 10:10 PM
  #132
Dave Wilshere
The aeroplane flies from grass with 60N, so thrust is not a problem. Wing won’t work as efficiently so keeping weight as low as you can is more critical, but Joker is lightly made, midi servos- just don’t add unessacary weight with internal paint etc.
Add a little more take off flap over figures ( +5mm) and you should be fine.
Dave
Old 01-19-2018, 04:02 PM
  #133
hk3957w
hk3957w's Avatar
thanks dave I will get 100N with your settings.
thanks again
javier
Old 01-22-2018, 07:40 PM
  #134
Desert Fox 1
Hello All,
Cheers!
Desert Fox 1
Old 01-30-2018, 07:47 PM
  #135
Bob_B
Bob_B's Avatar
Dave do you know which servo comes installed in the PNP version?
Old 01-30-2018, 10:14 PM
  #136
Dave Wilshere
The JR importers here had their own range done when JR servos went in the smaller sizes, branded MacGregor they are 3401 size MG. it’s a servo we have been using in things like a Mini Wizzard and other small size jets. The first yellow Joker I flew has them in it.
Dave
Old 02-01-2018, 05:51 PM
  #137
snatch-it
what are the differences of the joker compared to the graupner inspiration?
very similar looking model.
also does it fly any different to the inspiration?
I have money burning holes in pockets and a spare p100!!!
Old 02-01-2018, 10:12 PM
  #138
Dave Wilshere
Other than the canopy, it’s lighter. It has no ducting, lighter layup and different turbine mounting and thrust tube set up. The servo mount install is factory done and obviously the electric gear set up is different.
If you want to chat call me in the office.
Dave
Old 02-20-2018, 12:46 PM
  #139
opjose
opjose's Avatar
Has anyone installed gear doors on their Joker?
I just started working on mine and I would like to install doors.
BTW: The pictures here are very helpful.
Old 03-05-2018, 11:17 AM
  #140
opjose
opjose's Avatar
The Joker gets a cockpit.
Old 03-22-2018, 08:48 PM
  #141
opjose
opjose's Avatar
Finished
Old 03-23-2018, 12:45 AM
  #142
Dave Wilshere
Looks good!
Old 03-23-2018, 04:10 AM
  #143
skymaster68
Looks Great OpJose, I'm using this Joker Decals that I found on Ebay one the Red Joker that's on the way to me
Looks Great OpJose
Old 04-18-2018, 01:06 PM
  #144
opjose
opjose's Avatar
Please post pics of the Red one with those decals once you have it finished.
It should look great!
Old 04-23-2018, 08:25 AM
  #145
hk3957w
hk3957w's Avatar
good day gentlemen somebody is flying the joker with jeti?
Old 04-23-2018, 08:35 AM
  #146
Bob_B
Bob_B's Avatar
Yes do you have questions
Old 04-23-2018, 09:57 AM
  #147
hk3957w
hk3957w's Avatar
yes bob please can you sent me the model I want to check mixes like crow, flight modes, exponential and other settings. I am using the cortex pro but when I add the option gyro 1 in basic model, can not modify the gain. thanks bob
Old 04-23-2018, 10:07 AM
  #148
Bob_B
Bob_B's Avatar
It sounds like you need a later version of TX Firmware to adjust the Cortex pro in the Tx.
Old 04-23-2018, 10:12 AM
  #149
hk3957w
hk3957w's Avatar
I update the tx but is not only the cortex, the mixes like crow are really important and I not sure how to make it.
Old 04-29-2018, 05:02 AM
  #150
Midas D.
Look What just landed on my building board
Picked up at the Prowing fair in Germany by a flying buddy of mine, Thanks Nokki and Melanie from Carf
Afther unpacking and inspecting the whole lot, again you realize why each time i unpack a model from Carf the Grin on my face goes beyond the moon.....
Just Excellent quality and completely-ness, Just Briljant!!!!
I got an K85 on order for it but after putting the whole lot on a scale i came to the following,
- Fuselage 1734
- Wing 1950
- Nose 160
- Stab 280
- Canopy 100
- gear controller and covers 120
- Included Hardware 255
- Tank 90
- Pipe 380
Total weight 5069 Gr 5.069 KG
Hmmmmmm....
This make's me wonder if it wil stay under the 8.5 KG when fully ready and inc. full tank.....
So maybe go for the K100????
But this will add up the total weight with 500Gr, 0.5Kg according to KingTech specs, and fuel consumption will shoot up as well......
Saying all this, i think the K120 will come on the list then aswel, cause according to KingTech specs its just a Tat lighter, but then again a rise in fuel consumption, and will the airframe handle the load of a 120N??
Arrrggggg, what to do, cause i got to make an decision on the engine fast......
Please advise...
Cheers,
Ed
