Reload this Page >
CARF Joker build thread
Old 06-23-2018, 08:52 PM
  #326
Dave Wilshere
Old 06-24-2018, 08:00 PM
  #327
Midas D.
Got The Boca bearings inbound today or to morrow so i can swap them out.
And just as an protective measure i put one of these in between the nose gear servo and my receiver.
It should protect against a short, so better safe then sorry one i suppose ...
Hopfully i get her ready somewhere this week (if the kids leave me in peace )
Old 06-25-2018, 05:35 PM
  #328
setxws6
setxws6's Avatar
Quick question, anyone know the front to rear measurement (center section) of the Joker wing?
Old 06-26-2018, 01:44 AM
  #329
Midas D.
47,6 cm
Old 06-26-2018, 05:01 AM
  #330
Midas D.
Euh, can any one explain this one??
It was in the bag with the gear stuff..
Cheers,
Ed
Ps. i know what it is and what for, but on the whole thing no torx-bolts to be found..
Old 06-26-2018, 05:11 AM
  #331
dccatl
Cheers,
Ed
For the screw that clamps the struts in the gear trunion.
Old 06-26-2018, 09:04 AM
  #332
setxws6
setxws6's Avatar
47,6 cm
18.74 inches, thanks!
Old 06-26-2018, 12:30 PM
  #333
Midas D.
Default bearing
Check, just found out where they hide
Swapped out the bearings in the nose gear, quite some fiddle with "off-shore" hands
Thanks for the heads up Thumbler, sorry you had to go through the pain of breaking them first.
But it's wise to swap them in advance i guess, cause indeed, the stock ones break already by looking at them
Old 06-29-2018, 07:20 PM
  #334
setxws6
setxws6's Avatar
Proud new owner. It looks great in person and comparable in overall size to a flash but sooo lightweight. Got the PNP version but unfortunately won't be able to start on it anytime soon because of moving.
Old 07-11-2018, 11:38 AM
  #335
Midas D.
All the "internal's" are done
Now only the small bits to do, gear covers/doors, battery tray in the nose, CG and programming.
I'm almost there
Old 07-12-2018, 08:26 PM
  #336
TUMBLER
My Feedback: (13)
Got some Callie graphics on her
Old 07-13-2018, 02:53 PM
  #337
TUMBLER
My Feedback: (13)
Got lucky today! About three minutes into the flight the motor shut off and fortunately I was able toCircle the field and land on the runway. Try to restart the engine on the ground and no luck so I tested the pump with the fuel line disconnected and I’m getting no fuel to the engine so I am assuming I have a bad pump unless somebody has more experience with these things and can give me an idea what it might be.
Old 07-14-2018, 09:42 PM
  #338
Midas D.
Hi Tumbler,
Just a thought from my side....
Did you check that thin red and black wire that goes to valve on the pump?
That wire to me looks very delicate and there might be a break there due to "flapping about" over time??
Check it for continuity with a multimeter i would say....
But again, just a thought ...
Cheers,
Ed
Old 07-15-2018, 04:08 AM
  #339
TUMBLER
My Feedback: (13)
Thanks for the idea Ed. I should have mentioned that he pump actually makes a high pitch noise likenits trying to run and the motor is stuck and can’t turn.
Old 07-18-2018, 07:19 PM
  #340
kekelala
Hi, guys!
Does the PNP version come with electric brakes?
Thanks and cheers,
kekelala
Old 07-18-2018, 09:13 PM
  #341
Dave Wilshere
Yes, retracts and brakes
Old 07-19-2018, 08:23 PM
  #342
kekelala
Hi Dave, I appreciate the input.
Have a nice day!
kekelala
Old 07-21-2018, 10:54 PM
  #343
Midas D.
Ready for maiden.
Hope to get it done to morrow or Tuesday.
One question, what do you guy's do with the battery that goes in the gear controller box?
I got no switch in between, so i plug it in straight, but can you leave it there when the rest of the system is not powered up or do i need to pull the plug/connector out?
Cheers,
Ed
Old 07-21-2018, 11:41 PM
  #344
Dave Wilshere
I’d pull it out as I guess it will have a small constant draw
Old 07-22-2018, 11:41 AM
  #345
Midas D.
My maiden is delayed i think
For some reason my servo's freeze when i flik a switch?
It's the McGregor servos witch are in the PNP version in combination with futaba.
If i flik the flap switch sometimes the servo just or, does not go in to the crow position or does not come out it?
When i then slightly touch the stick it comes back alive normal??
Same if i flick to dual rate, sometimes one of the servo's freezes in the old position ..??
Other strange things if you look close to the video, if i let go of the stick, both elevator servo's start to flap in opposite direction???
This is the weirdest I've ever came across ...
any suggestions?
Every thing runs smooth and free and in servo test mode every thing works flawless.....
Cheers,
Ed
Old 07-23-2018, 09:38 AM
  #346
Bob_B
Bob_B's Avatar
How far should the k85 nozzle be placed from the pipe face?
Old 07-23-2018, 09:52 AM
  #347
Midas D.
Well i'm totally confused now.
just by experimenting with the above issue, i thought it might be an idea to swap out receivers.
So i went from an 7014 back to an old 6014 and from 7.4V back to 6V cause the 6014 does not like 7.4V.
guess what......
All problems solved........
I'm completely lost in space now, but the good thing, Maiden to morrow
Old 07-23-2018, 10:22 AM
  #348
Bob_B
Bob_B's Avatar
Sounds like the 7014 has issues??
Old 07-23-2018, 01:02 PM
  #349
Sparhawk
Sparhawk's Avatar
Have you tried the different modes that the receiver can do?
Old 07-23-2018, 06:56 PM
  #350
Midas D.
Hi Sparhawk,
Yes i did, tried them all that are available on the receiver, no succes.
Cheers,
Ed
