Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Fleet Brotherhood
Old 09-28-2012, 02:52 AM
  #126
Planejaw
My Feedback: (53)
Default RE: Fleet Brotherhood
ORIGINAL: retransit
I'm going to stick with the Pink-It. It is much closer to 1/4 scale. The pinking tape I used years ago on a full scale fabric wing was closer, in scale, to the 1/16'' dimension.
Bob
Bob, wanted to make sure that I gave a good explanation of my measurement. The 9/32" is the spacing lengthwise between one peak or one valley, to the next peak/valley. If you want me to measure how "high" each peak is, let me know. Glad to help.
Old 09-28-2012, 02:56 AM
  #127
Planejaw
My Feedback: (53)
BTW, I also bought a nice set of pinking shears (quite expensive from a fabric shop). That way, you can make the round reinforced patches around bolt holes and underneath the brackets for the N-struts. I also added these around the pushrod exits for the elevators control rods and the pull-pull exits for the rudder. Good reinforcement and looks scale-like as well. You'll pay between $30 and $40 for these.
Don't buy the inexpensive shears like you'll find in some craft stores like Mich_ _ _ _, they could only cut very thin paper, not covering material.
Old 09-28-2012, 07:04 AM
  #128
retransit
My Feedback: (18)
retransit's Avatar
That was a good explanation, John. No need to measure it again.
Bob
Old 09-28-2012, 07:08 AM
  #129
retransit
My Feedback: (18)
retransit's Avatar
Here's a shot of the pinking tape on a full size Boeing Model 40. The pinking is barely visible.
That's my next project at 1/4 scale (132"). I need to draw some plans.
Bob
ID:	1805721   Click image for larger version
Old 09-28-2012, 07:45 AM
  #130
Mein Duff
Mein Duff's Avatar
Gorgeous aircraft.....and big !!..nice detail shots.... thanks
Old 09-28-2012, 07:47 AM
  #131
Fleet
Well, get a towel...
http://www.fairchild24.com/392v/392v.htm
Ray W.
Old 09-28-2012, 09:01 AM
  #132
Mein Duff
Mein Duff's Avatar
OMG.....what a machine... definitely on my list now... would be nice with my Seidel 7 cyl radial..I wonder if Paul Matt ever drew that one up?
Old 09-28-2012, 11:33 AM
  #133
retransit
My Feedback: (18)
retransit's Avatar
Nothing like round engines, two wings and an open cockpit!
Checked Paul Matt for you, sorry, no dice.
Bob
Old 09-28-2012, 11:35 AM
  #134
Mein Duff
Mein Duff's Avatar
Must be plans for that somewhere...the search begins
Old 09-28-2012, 11:51 AM
  #135
retransit
My Feedback: (18)
retransit's Avatar
Good luck! Let me know if you find some.
Bob
Old 09-30-2012, 01:44 PM
  #136
Mein Duff
Mein Duff's Avatar
Bob, Here's a web site with Boeing Model 40 plans....hard to tell how exacting these might be...no detail shots...but its a beginning possibly
Old 09-30-2012, 01:45 PM
  #137
Mein Duff
Mein Duff's Avatar
Boeing Model 40 link
www.aeroaces.com/jamdrwgs2.htm
Old 09-30-2012, 03:03 PM
  #138
retransit
My Feedback: (18)
retransit's Avatar
Thanks Eric, but I have already ordered a set. On a thread I started concerning producing plans, someone gave me the link.
Here's the thread:
http://www.rcuniverse.com/forum/m_11239744/tm.htm
Bob
Old 09-30-2012, 03:24 PM
  #139
retransit
My Feedback: (18)
retransit's Avatar
Cliff Ozier came by my house today with his son. I got to show him how the Solartex looked and showed him the Pink-It rib tape. At least now he can get an idea of what it looks like before paint so he doesn't have to plunk down some money and be disappointed.
Bob
Old 10-01-2012, 04:43 PM
  #140
Fleet
Here ya go Bob, Boeing 40 vid.
http://youtu.be/Zag8Wwjz0bc
Ray W.
FBH #7
Old 10-01-2012, 05:39 PM
  #141
retransit
My Feedback: (18)
retransit's Avatar
Thanks, Ray. I hadn't seen that one. I have some video from Pemberton's site, that I downloaded to my computer, of the initial engine run and initial flight. Great stuff!
I can't wait to get started on it, but the Fleet must be finished first.
Bob
Old 10-05-2012, 01:42 PM
  #142
retransit
My Feedback: (18)
retransit's Avatar
I received the pinking tape order and proceeded to finish the fuse. I had to use white tape as the supplier did not have any natural tape in stock. The wings get covered next and then the fun job of tapeing the ribs and doing glue drops on the full length ribs.
Bob
ID:	1808136   Click image for larger version
ID:	1808137   Click image for larger version
Old 10-05-2012, 04:22 PM
  #143
Fleet
Neat work Bob.
I'm still waiting for my rotary cutter.   I found my old Fiskers and it works well.   I'm still wanting to know the size of the pinking...troubling as it is referred to as "wavy" and the 45mm is the diameter.  We'll see.   I'm cutting my tapes from iron on stuff.
Man, my wings are the size of ironing boards and are sucking up lots of dope.
Ray W.
Old 10-05-2012, 06:43 PM
  #144
Mein Duff
Mein Duff's Avatar
Very clean and tidy Bob....I'm envious
Old 10-06-2012, 11:08 AM
  #145
Fleet
Covering completed and now on to the doping the weave. Sucks up alot but that is OK.
I started to cut some tapes for the wings , etc. and I'm got the old cutting wheel out and the new cutting mat and all seems easier than I thought.
In 20 or so minutes , I cut enough tapes to do 2 wings and 2 ailerons. I got so infatuated I continued with the ailerons up to and including putting on the knots of RC56. So far so good.
A problem arouse and I'm not sure how to correct it even if I will correct it at all. As the fabric was shrunk down with the gun, the rib adjacent to the aileron deformed and leaves an unsightly bow. I'll be danged if I will uncover and lay in a gusset so I've been thinking of a dowel inserted at an anglefrom the outsideand glued in place. May not make it look better but it won't bow any more than it is.
Ray W.
Old 10-07-2012, 08:59 PM
  #146
retransit
My Feedback: (18)
retransit's Avatar
Moving right along there, Ray. I'm curious as to why you are using RC56 instead of white glue for the stitching?
I wasn't going to do it because I didn't have any problems with the wing spars on the previous Fleet, but I decided to wrap the inboard lower wing spars with fiberglass where the tongues are located. Instead of using epoxy, I used thin CA to stick it. The CA grabs the wood and fiberglass and makes a stout bond. It doesn't look very pretty, but looks don't count inside the wing.
Previously, the wing tongue receivers in the fuse have been bulked up over what the plans show to prevent them from coming apart due to loading from the tongues. I didn't want to have to re-visit that area after a period of flying abuse.
Bob
Old 10-07-2012, 09:06 PM
  #147
retransit
My Feedback: (18)
retransit's Avatar
Ray, something just came to me. The Fleet that you are modeling, was the fabric stitched to the ribs? The one I'm doing did not have stitching. Screws were used to hold down the fabric.
Bob
Old 10-08-2012, 04:19 AM
  #148
Fleet
They real Fleet I took pictures of, and with the owners direction said the horizontal stab, fin and rudder as well the ailerons were stitched where as the wing was screws into sheetmetal ribs.
As to the box spar beef up , yes. I'll look up my build site for a link but I used carbon fiber tow embedded with epoxy at first but on the later spars I used nylon carpet size twine wraps embedded in epoxy.
I cant find any market 6061-T6 plate for my spar couplers that will fit without shaving the thickness down so I'll figure something else.
RC 56 is more vinyl and survives brushing with thinned dope. An added plus is it holds it's shape better than elmers when applied.
Check Post #32 http://www.rcuniverse.com/forum/m_99..._2/key_/tm.htm
Ray W.
Old 10-08-2012, 06:16 PM
  #149
retransit
My Feedback: (18)
retransit's Avatar
Ray, this one doesn't look stitched to me. What do you think?
Bob
Old 10-08-2012, 06:25 PM
  #150
retransit
My Feedback: (18)
retransit's Avatar
By the way, I came across some pics of details and color schemes for the Fleet.
Bob
ID:	1809530   Click image for larger version
ID:	1809531   Click image for larger version
ID:	1809532   Click image for larger version
ID:	1809533   Click image for larger version
ID:	1809534   Click image for larger version
ID:	1809535   Click image for larger version
ID:	1809536   Click image for larger version
ID:	1809538   Click image for larger version
