Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Fleet Brotherhood
Old 03-16-2013, 09:17 AM
  #526
HOT COALS
Default RE: Fleet Brotherhood
   EAGLE 01. IF you want to stay with glow motors. You can use a S/T 2500. or S/T 3000. Mounting the cly side ways. I have 2 of my fleets mounted this way. THE S/T 2500 would be the better choise.  And priced right.  Hope this helps some.  HANK # 20.
Old 03-16-2013, 09:42 AM
  #527
HOT COALS
  Scott. John Mueler was the owner of the fleet. Who had lived in FT.WORTH TX.  Known as big John (big ).  2 fleets were builts  for him, 1 with break away wings, 1  solid 1 pcs wings . The builder was  H.I.G  Joshua, TX.   Hope this helps some. HANK # 20.
Old 03-16-2013, 11:07 AM
  #528
eagle 01
Hi:What do you think of a Moki 180 for it I just got one of them the other day.Have ample 120 4 strokes around too but maybe they are a little small!Sounds like you have had experience with the Fleet Bipes!Thanks Bob
Old 03-16-2013, 11:53 AM
  #529
HOT COALS
EAGLE  01. I am not familar with the mokie 180. THE 180 should do fine. Is the mokie a front carb ?. I would measure from the fire wall, to the end cowl  prop hub. This would give you a idea. I would  lay the cowl flat dn, with with motor inside. THis will give a idea.  I hope this helps some.  To date I have built 22  fleets, for a number of people. I am on my last fleet now for a friend.  Let me know how this turns out for you.  HANK #20
Old 03-16-2013, 12:41 PM
  #530
ScottMcM
My Feedback: (66)
ORIGINAL: HOT COALS
Thanks, I appreciate the info, and any more you might think of. The plane is in rough condition, but I can tell it was once a real beauty.
Old 03-18-2013, 04:07 AM
  #531
jmatusic
My Feedback: (16)
Sadly, it is time to sell my Fleet.
I think I have it over-priced because she's so darn pretty.
For anyone interested, here's the ad.
http://www.rcuniverse.com/market/item.cfm?itemID=906133
Joe
Old 03-18-2013, 07:42 AM
  #532
retransit
My Feedback: (18)
retransit's Avatar
The problem with our hobby is that when we go to sell something it becomes a buyer's market. Unless you overpayed for it, you may want to reduce the asking price. Or, if it's not imperative, just wait it out until you get what you're asking.
By the way, it's a real nice aircraft.
Bob
Old 03-18-2013, 08:51 AM
  #533
dabrown
dabrown's Avatar
Joe,
That's a beautiful airplane and easily worth the amount you're asking. As Bob said, you may have to wait for the right buyer.
Meanwhile, I'm struggling on building mine and it seems like it's taking forever. This weekend I made holders/jigs for the rigged left/right wing pairs and got the cabanes mounted inside the fuse. Should now be ready to initially rig the wings then tear down for painting.
Trying to post pics, but seems to be a problem...
Well it now seems to be working.
Dave
ID:	1863430   Click image for larger version
Old 03-18-2013, 10:00 AM
  #534
smkrcflyer
smkrcflyer's Avatar
Joe,
Very nice plane.
Do you know what engines were used to create the cowl?
Old 03-18-2013, 12:50 PM
  #535
retransit
My Feedback: (18)
retransit's Avatar
Keep at it Dave, you'll get it done.
Can you give me some insight on the attachments you have for the N-struts? I'd like to use something similiar on my Boeing Model 40.
Bob
Old 03-18-2013, 01:05 PM
  #536
retransit
My Feedback: (18)
retransit's Avatar
Joe, I sent an email with the RCU seller link and pictures to my club members.
Bob
Old 03-19-2013, 06:06 AM
  #537
dabrown
dabrown's Avatar
Thanks for the encouragement. I keep thinking I could've built 10 "Stiks" in this amount of time.
As far as the struts, on the top ends they are aluminum sheet pieces set into a slot sawn in the spruce stock. Put a small screw as a pin through the sandwiched wood/alum. The other ends are 4-40 threaded rod into a hole drilled in the spruce with Dubro 4-40 threaded rod ends same as I used for the ends of the flying/landing wires and also my tail bracing. Gives some adjustability. If you look at a real fleet, the rear N strut has what looks like a similar arrangement and I'm guessing it can be used to trim the rigging somewhat.
http://www2.gpmd.com/image/d/dubq1805.jpg
The Boeing has some unusual strut arrangements. Looks like it'll be lots of fun!!!
Dave
Old 03-19-2013, 10:38 AM
  #538
retransit
My Feedback: (18)
retransit's Avatar
I'm a bit dense, Dave. Can you post a closeup of the lower end fitting?
Bob
Old 03-19-2013, 05:25 PM
  #539
dabrown
dabrown's Avatar
Here are pics. Your Boeing is going to be really, really cool lots of unusual strut and wire arrangements!
ID:	1864317   Click image for larger version
ID:	1864318   Click image for larger version
ID:	1864319   Click image for larger version
ID:	1864320   Click image for larger version
ID:	1864321   Click image for larger version
Old 03-19-2013, 06:08 PM
  #540
jmatusic
My Feedback: (16)
Thanks to Bob, Steve and Dave.
Steve, not sure what engines were used but somewhere in this blog they were identified, just need to search through them all.
Joe
Old 03-19-2013, 06:34 PM
  #541
retransit
My Feedback: (18)
retransit's Avatar
Gooooooood pictures Dave! And nice work too.
The Boeing will be a bear to assemble at the field with the aforementioned struts and support wires.
Maybe it's my eyes, but is that streamlined landing wire? If not, does anyone have a source for the stuff because the full size Boeing has it.
Bob
Old 03-19-2013, 06:45 PM
  #542
jmatusic
My Feedback: (16)
Steve, see post 407 or 409 below for dummy motor, Williams brothers
Joe
http://www.rcuniverse.com/forum/m_36...m.htm#10772199
Old 03-19-2013, 06:56 PM
  #543
smkrcflyer
smkrcflyer's Avatar
Joe,
Thanks for the dummy motor info.
Old 03-20-2013, 10:09 AM
  #544
Mein Duff
Mein Duff's Avatar
Bob... I got my Streamilined flying wires from
www.flying-wires.ch/flying-wires/index.html
Hans Gautschi is a great guy to work with...Switz.
His wires are cold pressed stailess steel and exact replicas of WWI types used....Mine were 1/4 scale...not sure what other sizes he has...check out his web.
Old 03-20-2013, 10:10 AM
  #545
Mein Duff
Mein Duff's Avatar
I'm prety sure Mick Reeves in England has streamlined also
Old 03-20-2013, 01:42 PM
  #546
dabrown
dabrown's Avatar
Bob,
No, mine are all round with 4-40 threads on one end.
Boy, if you have a chance to look at the guy's website in Switzerland that Mien Duff provided, there are some fabulous looking airplanes with fabulous looking streamline wires obviously! Makes me want to go back to building stiks.
Dave
Old 03-20-2013, 03:49 PM
  #547
retransit
My Feedback: (18)
retransit's Avatar
You guys aren't making it easy to slow this build down. Thanks for all the info. I will check out Hans Gautschi's website immediately.
Bob
Old 03-20-2013, 07:37 PM
  #548
HOT COALS
steve, how did the plans turn out for you ?.  Dependining on how much you want to spend on motor. the S/T 2300 or S/T 3250 will work fine.  the fleet I am working on nown will have a S/T 3000 converted to gas. Found this in my motor cabinet  by luck. Forgot I had it. Brand new in the box.     HANK #20 .
Old 03-20-2013, 07:41 PM
  #549
HOT COALS
Any body interested,  K+ S has stream line wing struts. All sizes.   HANK # 20.
Old 03-21-2013, 03:20 AM
  #550
smkrcflyer
smkrcflyer's Avatar
Hank, The plans worked out good. I haven't done much with this plane yet. I have the elevator and rudder fixed I'm just waiting for the weather to warm up then Im going to see how the 325R5 runs. If its not running good I'm going to replace it that's why I was asking about engines.
