Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
Fleet Brotherhood
Old 01-13-2013, 09:14 AM
  #426
Kinner
Default RE: Fleet Brotherhood
Since it will be uncovered, it's a good time to check over those old glue joints.
Ray W.
Old 01-13-2013, 09:41 AM
  #427
HOT COALS
    Thanks Ray.  Been there ,done that.   Hank  # 20
Old 01-13-2013, 09:45 AM
  #428
HOT COALS
  I am going with F/M enterprise covering BOB.  HANK #20 .
Old 01-17-2013, 07:16 AM
  #429
retransit
My Feedback: (18)
retransit's Avatar
Pardon my ignorance Hank, but what is F/M?
If the front moves through Florida before the weekend and takes the winds with it, it looks like Saturday or Sunday for my maiden flight. I had my first crash yesterday while attempting to range check my Tx/Rx. I placed the Fleet in the driveway, retrieved my Tx from the garage and the pilot released the brakes. The Fleet went rolling down the incline, crossed the street and banged into the curb. No damage, as it hit on the wheels. As I saw it start to roll all I could envision is a car coming down the street and squashing it. I gave the pilot a verbal reprimand.
Seems RCU isn't notifying me of updates to the Brotherhood as it used to. I have to occasionally check in to see what's new.
Bob
Old 01-17-2013, 07:43 AM
  #430
HOT COALS
F&M ENTERPRISES.COM.  PHONE  817- 279 - 8045. GRANDBURY, TX.  Look at their web site Bob. SORRY to hear about your mis hap  in driveway. Yes I am having trouble with R C U .   HANK # 20
Old 01-17-2013, 07:50 AM
  #431
HOT COALS
send for the vido Bob. Ask for the sample pack. Balsa u s a sells the poly tack much cheaper.  You will find this cover goes on very good and strong.  Hank # 20 .
Old 01-18-2013, 03:36 PM
  #432
retransit
My Feedback: (18)
retransit's Avatar
Since Solartex is glue backed, I'll stick with the one-step method.
Bob
Old 01-19-2013, 04:36 PM
  #433
Kinner
Well Bob, looks like we won't be making the Deland Fly-in. Motor was good and strong but a case of dumb thumbs in the sun and ...
What a dust cloud it threw up. Picking up the pieces was the easy part as the landing and flying wires all held it to one heap. Sadly, the pilot was ejected from the cockpitand was hanging in his shoulder belts.
The very long walk back was made longer by having to traverse a small irrigation ditch that turneddeeper as I stood in it.
Bird is repairable but it will take some time.
I still plan to take in some grandchild time so we may drag her brothers over to the show and meet you face to face.
Ray W.
ID:	1842260   Click image for larger version
Old 01-19-2013, 07:01 PM
  #434
retransit
My Feedback: (18)
retransit's Avatar
Sorry to see that. Hope you can make it to the show.
I'm going to maiden mine tomorrow.
Bob
Old 01-20-2013, 10:40 AM
  #435
HOT COALS
!! OK !! One of the fleets is strip dwn. CKed all glue joints . F/W alumminum trianglemount bolts have rusted out over the year's. Landing gear bolts threads have rusted out. Wheels need to be replaced. Aluminum  tonques have to be replaced. mounting holes are strip.  HANK #20.
Old 01-20-2013, 10:50 AM
  #436
HOT COALS
# 2 Wings are in good shape. NO warpage . Stab & elev. need replacment ( warpaage ). Windshield glass & intrument panel ( replaced ).  All servoes need replacement.  This fleet had a S/T  3000 mounted.  HANK 20
Old 01-20-2013, 10:57 AM
  #437
HOT COALS
Sorry to see that photo RAY !!. Can it be repaired ?.  HANK #20.
Old 01-20-2013, 11:05 AM
  #438
HOT COALS
Good luck on your flight BOB. Today I am going to try my new 5 cyl in in my 10yr fleet.  Hope things go well.     HANK # 20.
Old 01-20-2013, 11:26 AM
  #439
Kinner
Yup Hank, she is repairable but with lots of long term as I've some other planes to finish before hand.   I can get my other larger Fleet ready for a Spring maiden so that is first.   Now, seeing as I was rather rusty at the sticks, I may finish off an already framed up BUSA L-4 just waithing for covering and my new Saito 150.
I went in the trailer and sorta looked the ole bird over and see that un-cover and repair of the front ot the fuse is in order.  Maybe , that will be the best time to redo the color scheme as well.
Hoping to be hearing some good news from Retransit soon.
Ray W.
Old 01-20-2013, 08:16 PM
  #440
retransit
My Feedback: (18)
retransit's Avatar
My Fleet completed its maiden today. Weather was just about perfect with virtually no wind except for a small quartering cross. Anyway, I had a buddy of mine do the initial because I was shooting the video and I wimped out. He was good enough to do it. Excellent pilot.
I finished the flight off, doing a loop and then landing about a minute later. Total airborne time was about ten minutes. I had about a third of a the 32 oz. tank left after shutdown. I have to shim the right rear cabane to get the leading edge to drop some positive incidence. It had a tendencey to roll left on takeoff. I also have to place another shim under the horizontal stab leading edge, as it wants to climb when increasing power. Everything else is OK and the engine ran beautiful. Must have been that little adjustment toward lean on the low speed needle. It had absolutely no tendency to drop a cylinder upon increasing power without the glow driver engaged. I finally did something right! it was peaked at 6150 rpm with a 20-10 Xoar prop.
Here are a few pictures taken at the field and the video.
Bob
[youtube]http://www.youtube.com/watch?v=gbZxPgdZMBU[/youtube]
ID:	1842731   Click image for larger version
ID:	1842732   Click image for larger version
  #441
HOT COALS
    HO RA!!!!. MY FLEET # 7 TOOK TO THE AIR.aFTER A FEW TRM ADJUSTMENT'S. SHE FLEW BEAUTIFUL. lANDINGWAS A BIT (HAIRY ). COULDN'T GET THE IDLE DWN, TO FLAIR OUT. SO FAR 6 FLIGHTS. HAVE TO CK. SERVO LINGAGE ?.  4 OF MY FRIENDS HAD THEIR WAY WITH HER.  ALL WENT WELL , EXCEPT FOR THE IDLE. NEXT TIME I WILL USE THE BALLON TIRES FOR THE GRASS. HANK # 20 .
Old 01-20-2013, 08:39 PM
  #442
retransit
My Feedback: (18)
retransit's Avatar
That's great, Hank!
Bob
Old 01-20-2013, 08:53 PM
  #443
HOT COALS
    THANK'S  BOB. TODAY WAS A GREAT DAY. HOPE THE EASTER BUNNY BRING'S ME A NEW COMPUTOR. SO! I CAN SEND PHOTO'S . GLAD TO HEAR YOUR DAY WENT WELL.  HANK # 20.
Old 01-20-2013, 08:57 PM
  #444
HOT COALS
    PHOTO'S LOOK GOOD BOB. THINK MAYBE I TAKE THE TIME TO DETAIL ONE OF MINE.  HANK # 20
Old 01-20-2013, 09:17 PM
  #445
retransit
My Feedback: (18)
retransit's Avatar
Click on the top picture, Hank. It's a link to a Youtube video.
Bob
Old 01-20-2013, 09:50 PM
  #446
Cliff Ozier
Sorry to hear Ray. Still hope you can make it down. I'm going to try to be there.
Nice to meet ya Hank.
Bob, I finally have my Fleet in my shop.
Looks to have been covered w/Solartex.
I think Im going to peel the bottoms off of each piece for inspection and gluing.
Still taking down computer animated Christmas light display first.
Will bring it to the show for static display.
Cliff
Old 01-21-2013, 09:02 AM
  #447
retransit
My Feedback: (18)
retransit's Avatar
The Christmas lights or the airplane?
Bob
Old 01-25-2013, 10:43 AM
  #448
dabrown
dabrown's Avatar
Bob,
Got my wings covered and pinked tape done...
On the Concept Fleet thread you installed simulated screw heads on the wing/taping and I'm thinking about giving it a try. Did I recall that you used epoxy? I did some tests of Elmers wood glue, canopy glue and epoxy, and the epoxy seemed to work best. The problem seems to be to get a consistent size drop. Any hints on this?
Dave
Old 01-26-2013, 07:26 PM
  #449
retransit
My Feedback: (18)
retransit's Avatar
I used a stick of balsa with a pin inserted into it. The stick is just something to hold the pin while you dip the pin head in white glue (Elmers, Titebond, etc.) Map out your spacing with a pencil and start. Mistakes can be easily wiped off or picked off when dry.
I've used a syringe in the past, but the pin works better for me.
Check out this video I made:
http://www.youtube.com/watch?v=b1xYF...e-nzQ&index=20
Bob
Old 01-26-2013, 08:37 PM
  #450
HOT COALS
   If you go to your arts & craft store. go to the bead section. where they sell the glitter stuff, here you will fine  automatic rivets in different sizes. I had used them on a lot of war birds. since I can't send photos on this computor. they look like this.   o-o-o-o-o- . you will get about 200 on a roll.  2 rolls per pkge. about  $ 1.99 . you can cut the rivets inbetween. Or keep them attached.  sray your primer coat. and your paint color. never know the diference. And saves time. Company name Darice inc.  www.darice.com  . I hope this helps some.   HANK  #20
